A couple comments on the last 60 pages:
1. ABS is really a necessary safety feature. Sub-$10,000 motorcycles have it as an option
2. There is no federal rebund or rebate on 3 wheel motorcycles. Unless the current EV bill passes, at which it might. The Oregon $2500 refund requires you to own it for 2 years before selling/transferring
3. Doors took over 2 years to design and manufacture. It was because of fitment but also for liability concerns. If the door isn’t well tested and in an accident ends up hurting someone …
4. Torque vectoring will likely only be made available at slow, parking type speeds
5. Rentals in Eugene went from $16 an hour to somewhere around $30 an hour
6. I use ally.com for stock trades. Cheap $5 trades, responsive (when I deleted my email on how to vote), they give you year end statements
7. They use the term “upper frame” instead of roll cage because it is crush tested to car specs, not roll over tested.
8. Eagle/gull doors are likely not possible. They would weigh too much, require attachment points that would likely then trigger crush testing again, and they look like they stick out a lot when opening /closing
9. Solar roofs cost more than the benefit you would gain from them. They are mostly a gimmick at this point
10. The first MLM will likely cost over $10k. The cheapest version is likely at least a year or 2 away and might be released at $3000-$4000. Just got surveyed on it with “how much are you willing to pay” questions
11. I don’t know if Reacher can really get his pension money via Western Union. My guess is he has a buddy cash it and the buddy sends money via WU every so often. The bigger question in my mind is why does he buy clothes every 3-5 or so days and throw them away. Super wasteful.
