Thread: Prius 75-91mpg
Old 08-06-2022, 07:22 AM   #299 (permalink)
Nathan jones
Ecomodding Apprentice
That is true in detail but in the UK tests show the worst premium fuel contained 8%. None had less than 5
By adding ro or deionized water, shaking and letting rest you can filter it but I don't have time. Also by the time valve heads and piston surface are sufficiently degraded my bearings will all need replaced
My brake lines are ok at the moment but has anyone experience of aluminum lines used on airplanes? I can get 1800 psi stuff and it's used the same way as copper, just not 8gcm
And real experience...??
