Originally Posted by wagonman76
Youd rather drive at night because the reduced visibility gives you an excuse to go slower.
Or.... You rather not drive at night because you can't stand thinking about the drag the alternator puts on your engine due to the headlights being on.
Spinoff......An oncoming state trooper flashes his high beams at you at dusk to let you know it's time to turn the headlights on (happened).
.....You're calculating when your wife is going to start talking to you again after she discovers that you unscrewed her FM antenna and removed her roof rack cross members (that she uses sometimes).
.....Your coworker sees you pulling in to the parking lot when he stops walking and puts his hand up to his ear to find out if your engine is running or not.
.....Your coworkers expect you to report on your latest tank MPG.
Barna
