Old 08-10-2022, 02:41 AM   #43 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Isaac Zachary View Post
I find it funny that we compare the modern automatic to the not-so-modern manual. Manual transmissions haven't changed much since synchromesh was introduced. Automatics are totaly differnt animals than what they used to be.
That's a good point.
If someone would make a modern manual transmission, (maybe an automatic with the option to shift into whatever gear the driver wants is a modern manual transmission) then maybe we could have a fair comparison.
IIRC in some previous-generation Mercedes-AMG model the torque converter of the automatic transmission was replaced by a multi-plate clutch in order to provide a more direct engagement. Not sure how it improved or decreased fuel-efficiency. But anyway, considering how the so-called automated-manual transmissions emerged as a lower-budget alternative to automatics, with the expectation of a better fuel-efficiency too, going the other way around would seem quite odd...
I think sequential shift dog clutch transmissions should be offered as modern manuals.
As motorcycles usually feature a sequential transmission, maybe it wouldn't be so pointless at all to have a similar setup on cars. IIRC some aftermarket suppliers have conversion kits for some mainstream transmission, including straight-cut gears with non-stock ratios, even though those are more focused for racing usage.
