Originally Posted by WaxyChicken
Ben Nelson:Infact, in the exploded diagram it almost looks like it's a female end rather than a male gear that is on my motor. perhaps a modification for the forklift production use of this motor? it does not appear to come off the shaft but i'll take another look. perhaps the oil seal ring can fit around it when it comes off.
Don't know, but I'd guess the diagram shows a female spline end and the gear on your motor is just the visible end of an adapter stub shaft (with a male spline end) held in place by a roll pin (or perhaps by #6 retaining ring in the diagram. Don't see how you'll get that end apart with out prying the oil seal out of the way so you can remove #2 retaining ring.
The spot-welded nut and bolt is welded in 2 places - opposite sides of the nut/bolt. I'll take another whack at trying to get that off. the hardest part is that in trying to turn the bolt/nut is that the entire shaft turns and it's hard to brace it. i will start with a chisel and filing down those welds.
Starting with chisel and filing is likely a huge waste of time. The nut/bolt is probably a mechanic's ad hoc field fix to replace a bolt that had an oversize head - the nut is probably just acting like a large washer. Honestly, a 1/2 pneumatic impact will almost certainly spin the bolt/nut comb loose with out a problem and no need to brace the shaft - the inertial mass of the armature will let the pneumatic impact do it's job.
In any case, good luck. Let us know how it goes.
