Old 08-11-2022, 12:44 AM   #473 (permalink)
Phase
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Cardboard and duct tape rear diffuser. Obviously the edges will be a lot cleaner and more flush.
Final plan is to use abs plastic and drilled in under and then use some type of bracket to hold it
Aiming for 10 degree angle while slightly curving the whole time
Boat tailing behind rear wheels will be added and then two extra inner fins to block off some inner wheel well turbulence
Any advice or suggestions?
Is this a good shape? What should I do differently?
ID:	32719   Click image for larger version
ID:	32720   Click image for larger version
ID:	32721   Click image for larger version
ID:	32722   Click image for larger version
The Following User Says Thank You to Phase For This Useful Post:
aerohead (08-11-2022)
