Old 08-11-2022, 11:55 AM   #45 (permalink)
aerohead
if someone would make
Originally Posted by Isaac Zachary View Post
I find it funny that we compare the modern automatic to the not-so-modern manual. Manual transmissions haven't changed much since synchromesh was introduced. Automatics are totaly differnt animals than what they used to be.
If someone would make a modern manual transmission, (maybe an automatic with the option to shift into whatever gear the driver wants is a modern manual transmission) then maybe we could have a fair comparison.
I think sequential shift dog clutch transmissions should be offered as modern manuals.
Some automotive journalists have mentioned the following reasons automakers will never build what you desire:
* Automatic transmissions can satisfy EPA Clean Air Act standards/regulations- CAFE Standards, whereas manual transmissions cannot.
* Automatic transmission cars cost less to manufacture and return higher profits.
* There are more consumers who desire automatic transmissions than those who don't.
* A manual transmission can never be shifted as fast as an automatic, and will always waste some energy between shifts.
* Unless a manual transmission had 12-gears, it could never compete against a CVT transmission, and the 'tiny' ratio splits it provides.
* It is these small gear splits which help the engine remain in it's most favorable island of BSFC, consequently returning the highest thermal-mechanical efficiency, lowest fuel consumption, and lowest exhaust emissions.
* In two years, BEVs will cost the same as ICE automobiles, and since BEVs get 3.5X higher fuel economy than ICE, there will no longer be any rational reason to purchase or manufacture ICE vehicles, or transmissions as are currently manufactured.
* After the electrification of transport is complete, 'transmissions' will be known only as museum pieces.
Ecky (08-11-2022)
