Old 08-17-2022, 12:26 AM   #19 (permalink)
S Keith
Originally Posted by Snax View Post
Interesting to note that most of the older hybrids in this auction show "BATTERY SYSTEM ISSUES". Only the 2007 or newer don't list that, but I'd be hesitant when it comes to age in general.
There is no cut-off line. 04-09 represent substantial risk. 08-09 are higher in hot climates. They have a tendency for the batteries to physically leak and disable the car.
Expect another $4-5K in repairing auction G2 Prius. Assume bad battery and ABS actuator.
Originally Posted by Isaac Zachary View Post
There's a 2008 Ford hybrid on that list that says "hybrid battery failure, will need towed."
More often than not, the FEH/MMH simply need a recharge. 05-08 have a built-in jump starter that allows on-board charging from the 12V (best if done attached to a running jump vehicle). 09+ do not have the jump starter and must be disassembled and charged. I do 1-2 dozen a year for folks that let them sit until they discharge. Pandemic had me particularly busy with 09-10. Had 4 on site at one time.
The Following User Says Thank You to S Keith For This Useful Post:
Isaac Zachary (08-17-2022)
