Originally Posted by ennored
Other ratios listed are for the 4 speed. That's what E450s got in 2004 when they had a gas engine.
so, which is the ones i should expect, min or max?
Originally Posted by ECO-AKJ
The transmission will be a 5-speed, single shifting between gears, the torque converter will lock up in every gear except 1st.
I wouldn't go to 3.08 gearing, 3.55 would be better, you could change the rear wheels to srw, then put wheel arch covers.
So - i doubt i need duals for my payload (but i can weigh it and verify) but 2 less wheels and tires to deal with would be
just fine by me
