Originally Posted by Caddylackn
The double wheel rear axle is a wider axle than a single wheel rear axle set up. So no, you can't safely take a wheel off each side
good to know.
You would have to run a load E range tire for the weight.
yeah, i have E range now.
You will probably only find a one ton rear end with 3.54 or 3.08 in a diesel. Another problem is the driveshaft and the yoke. You need to find a rear end that will take your yoke from your ex. rear end or has one the same size, or you have to modify the driveshaft.
A 3/4 ton rear end may work, but I think you will be too heavy for them.
hmm. sounds like probably more work than it is worth considering this is a recreational vehicle. probably i'll see if i can find a 3.54 or 3.73 since those are available as a factory option for the F series and i would expect the carrier to be the same even if the axle length is different.
i'll ask around on the ford enthusiasts forum, they seem to have a lot of knowledge when it comes to these sorts of things.
