Thread
Ecomodding 2015 MX-5 Miata
09-03-2022, 01:41 AM
46
permalink
Ecky
ND Miata
- '15 Mazda MX-5 Special Package
90 day:
39.72
mpg (US)
While waiting on some supplies to come for building a temporary coroplast belly pan and diffuser, I installed a hitch, rated for 900kg/2000lbs. The receiver bar mounts sandwiched to the end of the frame rails, and has braces that extend underneath and forward to prevent twisting torque. It has a clever extendable (and removable) receiver, that I plan to leave detached most of the time, to shave a bit of weight. When not attached, nothing hangs down under the car in the airstream. Total weight is around 10kg (22lbs) with the receiver elbow attached, a bit less without (didn't weigh it).
I got some good underside pictures as well, to better plan my pan.
Honda Insight w/Acura TSX engine
2000 Insight TLC & Build Thread
freebeard
(09-03-2022)
Ecky
View Public Profile
Send a private message to Ecky
Find More Posts by Ecky
