Old 10-15-2008, 09:40 PM   #11 (permalink)
thefirebuilds
Puddles - '95 Geo Metro LSI
90 day: 39.52 mpg (US)
Spec Miata - '91 Mazda Miata Club Racing
Scooter - '05 Honda Metropolitan
Monstro II - '99 Dodge Ram 1500
Kassia - '01 Mazda Miata LS
Precious - '97 Chevy 3500 Silverado Dually
Originally Posted by taco View Post
i was always told that during weight trasfer u wanted morw weight over the drive wheels, i.e hitting the apex of a turn rolling iin to the throttle weight shift to outside rear, with a 50-50 on a fwd that would cause hardly no weight on the front inner tire , with most open diff setups the inside tire would spin case as little as 10% of the cars weight can be on that tire.(non sport stock suspension) now in a rwd set up that would be optimal for traction
no, that's wrong. In the apex of a turn the more weight on your leading tires the less traction you will be able to manage. You need dynamic weight on the wheels, but too much static weight to start with and you understeer or "plow like a pig" as a metro does from the factory.
the opposite -- too much weight in the back -- results in oversteer, which is unpleasant as well.
Corner weight on a race car should be 50.05% at most, and ideally 55% or less front to back difference. That front to back is a lot harder to manage when working within strict rulesets, like a spec or showroom stock series.
I do see your point, however, with a FF car, there may be some benefit to leaving a turn with a little extra weight out front, but the snow plow effect diving into a turn may negate that.
