Old 10-15-2008, 08:40 PM   #11 (permalink)
Puddles - '95 Geo Metro LSI
90 day: 39.52 mpg (US)
Spec Miata - '91 Mazda Miata Club Racing
Scooter - '05 Honda Metropolitan
Monstro II - '99 Dodge Ram 1500
Kassia - '01 Mazda Miata LS
Precious - '97 Chevy 3500 Silverado Dually
Originally Posted by taco View Post
i was always told that during weight trasfer u wanted morw weight over the drive wheels, i.e hitting the apex of a turn rolling iin to the throttle weight shift to outside rear, with a 50-50 on a fwd that would cause hardly no weight on the front inner tire , with most open diff setups the inside tire would spin case as little as 10% of the cars weight can be on that tire.(non sport stock suspension) now in a rwd set up that would be optimal for traction
no, that's wrong. In the apex of a turn the more weight on your leading tires the less traction you will be able to manage. You need dynamic weight on the wheels, but too much static weight to start with and you understeer or "plow like a pig" as a metro does from the factory.
the opposite -- too much weight in the back -- results in oversteer, which is unpleasant as well.
Corner weight on a race car should be 50.05% at most, and ideally 55% or less front to back difference. That front to back is a lot harder to manage when working within strict rulesets, like a spec or showroom stock series.
I do see your point, however, with a FF car, there may be some benefit to leaving a turn with a little extra weight out front, but the snow plow effect diving into a turn may negate that.
Old 10-15-2008, 08:45 PM   #12 (permalink)
What happens when you sit in it?
Old 10-15-2008, 08:54 PM   #13 (permalink)
in the race car i worry about this, I mitigate with 204#s of lead in the driver seat and floorboard, in the street car i was just after curb weight.
Old 10-15-2008, 11:07 PM   #14 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Granted a balanced vehicle is a must, lightening the car, regardless of the drive train, will allow you to move with less rolling resistance and with more powerful acceleration and higher top speed (within the mechanical limitations of the car). There really is no substitute for lightening a vehicle.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 10-15-2008, 11:11 PM   #15 (permalink)
absolutely, we are completely off topic at this point and you're right.
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Saved a Geo Metro and saved big $ (stopped driving my pickup) Johnny Mullet Success Stories 24 05-08-2010 12:15 AM
Planning Project Eco-Z seanof30306 EcoModding Central 20 08-24-2009 10:00 PM
Metro Hoarding 101 - also: Metro pickup trucks! Cowspots Introductions 28 04-14-2008 07:26 PM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 04:05 PM
