Old 09-30-2022, 11:06 AM   #3 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Toe in is stable, toe out is unstable (the vehicle can't figure out which side to follow).
On solid rear axles, toe isn't a problem because it is very close to zero.
Camber tends to cause good cornering, but at the expensive of tire wear. So it is very important to get the toe very close to the target value if you want good tire wear.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
The Following User Says Thank You to CapriRacer For This Useful Post:
Piotrsko (09-30-2022)
