Originally Posted by Piotrsko
I am wondering how you aren't getting build up in the chimney or flue on your furnace. Lot of that stuff doesn't fully burn
I get it really hot. Only thing that smokes is tires.
Originally Posted by Xist
Is your scrap steel all approximately rebar-shaped?
I have old brake rotors, which would make poor candidates!
It's anything. Barbed wire, cabinet sliders, bits of chain link fence, lawn mower blades, cutoffs, old pipe, wire grids, nails and other hardware.
Steel reinforced concrete tears itself apart through spalling. If you want something permanent use glass or basalt fiber.
I pour a layer, add the steel keeping it at least 2 inches from the edge and put another layer on top of it. So it's a concrete sandwich with steel in the middle.
