Originally Posted by Phase
Or just not use an old Prius and use a newer Prius or Ioniq or any other modern hybrid. I get 33mpg when driving at 115 mph. Only did it for a few min in the Arizona desert. Kinda scary cruising at 115 thru hilly one lane roads honestly.
On my run i used a 2017 4th generation prius. As the gen5 is not out yet i fail to understand what you are implying. So you managed to get 33mpg at 115 for a few minutes. For a few minutes is not the same as 33 hours at those speeds. The spreadsheet my virtual team kept shows the average speed per hour on my run. The highest was 97mph. There were a total of 14 hours where the average per hour was over 90. The lowest was 57 for the last hour in California. I can assure you that multiple hours at 115 will not bring a 33mpg result in any hybrid car.
