Originally Posted by Tmugz88
The rims I bought didn't fit , rhey were removed from an 04 honda according to the guy i bought them from. They bolt up but the front calipers are pressed right up to the rim. Thay won't allow the calipers to release which is how I figured out the issue , the vehicle wouldn't move.
Aside from spacers I belive they and the mounting of my winter tires were a waste of money.
Ahh, not the right offset. Spacers are the only way then. 5mm typically does the trick, and works without any foolery with the lugs.
