Old 10-31-2022, 08:26 PM   #43 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by Tmugz88 View Post
I went with the ones I sent before seeing the message , I'm not seeing anything on ebay for $4 either but I'll keep digging.
Would I need to use all 4 or due to only my fronts causing the issue would just using spacers up front be sufficient and safe ?
You might choose to put them on the rear, to get the track width the same, but I imagine it would make little difference if you didn't. Not with that small of a spacer.
