Old 11-02-2022, 10:42 PM   #12 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Originally Posted by JapaneseJeep View Post
This last paragraph captures exactly the spirit of what I'm after. Is it going to be the best option? Absolutely not. Is it going to be a little silly and of questionable commercial value? Sure... but what I want is to know whether or not it will make a significant MPG increase, all other factors be damned.
Now the question is how well this will actually translate when I simply don't have access to the equipment or know-how needed to safely and efficiently bottle my generated hydrogen/HHO.
Botting high pressure hydrogen is dangerous and expensive, but assuming you can do it, the gains would be proportional to how much hydrogen you can carry/inject. Most HHO systems amount to a tiny fraction of a percent.
Engineering Explained released a video on hydrogen combustion just a few days ago. IIRC, the conclusion he came to was that, for a very efficient V8, a 60L tank (think large street-side trash bin) filled to 5000PSI with hydrogen would be good for around 60 miles of hydrogen-only range. If you're going half and half with gasoline, you could double your fuel economy for the first 120 miles with a tank just about the size of the rear passenger compartment in most sedans.
With a much more efficient engine, say a Geo Metro 3 cylinder, you could get the same doubling of economy for around 500 miles per hydrogen fill.
JapaneseJeep (11-02-2022)
