Old 11-05-2022, 05:54 AM   #24 (permalink)
Logic
Yeah I saw that. The tests used employed bottle fed hydrogen and appear to use far more hydrogen than an hho machine can make.
Yep; the "How much HHO can a HHO machine make" is something I keep an eye on. Something like buying a lotto card...
There's a whole 'fringe community' online who like to tinker with this.
Here's a new PDF (unread as yet. Looong!) on more or less where they're at:
https://www.academia.edu/21986732/Re...ard=view-paper
That's all Unicorn Corral stuff, most oftten revolving around finding the resonant frequency/ies that blast H2O to bits with very little power.
Light s also also in their conversations and some proper research on light as a catalyst is available.
Lets hope someone gets it right and it's reproducible... and doesn't 'disappear'.
The one test showed that adding hydrogen improved fuel economy by a third. How do we know they induce a problem and then fake fix it with hydrogen.
The best way I can think of would be to run the engine at low load, at mid range RPMs, retard timing to reduce fuel economy and then add hydrogen because we know hydrogen burns really fast to make it look like the hydrogen increased fuel economy.
Where if the engine was running properly the hydrogen would have only increased fuel economy by a lab measurable amount.
Yep there are ways to cheat.
And often employed by people trying to sell crappy, open cell, serial HHO cells:
  • Boil the electrolyte to get big bubbles, either by running the cell hot or pulling a vacuum on it.
  • Use huge amounts of power/voltage.
  • Mess with the initial ignition timing etc.
But a lot of the studies are done by engineering students to get their thesis/degree.
These people don't stand to benefit financially and would get their degree whether the experiment showed an advantage or not.
So no reason to cheat..?
Many of them do show benefit. Even from a alternator run cell.
If one goes by the # that do vs those that don't; things remain interesting, but not interesting enough to tinker with unless you have 'school fee' money to burn.
Personally I feel that using the waste heat (exhaust mostly) to produce a fuel or add value/energy to it is most interesting.
I note that Syngas, is commercially produced at temperatures below those of a std car exhaust.
(Imagine being able to substitute 75 to 90% of your fuel with water! )
But the pressures used for optimal H2 production are dangerously high and would add much weight to a car.
Then there's the fact the the added heat for the reaction isn't in the "6 to 9 parts water to one part fuel" equation and takes fuel somewhere.
But what if the enough Syngas/H2 can be easily produced (lower pressure) to actually run lean or retard timing, ..??
The remainder of the gassified fuel remains fuel and the steam, steam.
Both show advantages in ICEs..?
MIT's Plasma Fuel Reformer was headed in this directoin before dropping off the map.
I 'heard' it was bought out and shelved..?
https://www.greencarcongress.com/200...eritor_cl.html
