Originally Posted by Logic
A link to links:
https://www.google.com/search?q=agrg...hrome&ie=UTF-8
Important point:
Boric Oxide + water = Boric Acid.
Which is what forms the ceramic layer on the metal surface/s, much like the very thin oxide layer that forms on aluminium almost immediately, then stops all further oxidation...
The finer 'how to' points I will get into when time allows.
If you think I'm going to put water and Boric Oxide in my differential you are nuts. This research goes back to 2004. If there was a way to apply it the oil companies are doing it.
