Old 11-15-2022, 12:34 AM   #557 (permalink)
freebeard
Estimates are not equal to tuft tests.
If the upstream streamlines are moving up or down instead of straight back (in or out on the top) the new construction should anticipate or control that so the streamlines separate cleanly.
Shows up mostly in the lower corners, behind the rear wheels. Morelli's FIAT had turbine wheels that fed a duct to the diffuser area. I like skegs.
