Old 12-03-2022, 05:25 PM   #107 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
It is routine for US models to have shorter maintenance intervals than European models. For example my 2005 and 2009 Prius called for oil changes every 5,000 miles in the USA and every 15,000 km in Europe. Same oil specified. This is due to manufacturers knowing that US customers do not following the factory maintenance schedule.
I just scoped my cylinders in the 2006 Prius with 215k miles and the block is junk. Regardless of the oil change intervals the previous owners did it didn't keep it from tearing chunks out of the cylinder walls. And you can't bore these engines so my engine is now junk. Three cylinders have chunks missing out of the cylinder walls and all four have grooves.
