Old 12-04-2022, 03:14 AM   #110 (permalink)
cRiPpLe_rOoStEr
European auto manufacturers quote long service intervals because they expect customers will use the correct specialized fluids required to achieve those long service intervals.
And the downsizing is also a matter of concern, as turbocharged engines tend to be way more sensitive to lower-grade oils than most naturally-aspirated engines were around 20 years ago. Besides turbo-lag which may be quite critical in some regions, to the point of almost neglecting any practical benefit of downsized engines.
In Europe that isn't a problem - most people actually follow the maintenance schedule. In the USA - a BMW is just as likely to get bulk Jiffy Lube oil as the euro spec oil.
No wonder Volkswagen retained that 5-cyl 2.5L naturally-aspirated engine for instance, as it was more redneck-proof than the TSI engines fitted to Euro-spec versions of the Golf and the Passat back in the day.
JSH (12-04-2022)
