Thread: rear wheel arch
Old 12-08-2022, 11:40 AM   #8 (permalink)
aerohead
'box-cavity'
Originally Posted by Phase View Post
Can you explain how their box cavity reduces drag?
I'm presuming that you're discussing Coventry University's Audi A2 modifications?
If so, then, looking from behind, the rear-extending panels, which follow the perimeter of the cavity, combined with blocking plates, which separate each cell of the cavity, around the periphery, loosely define where an actual boat-tail would terminate, at that distance behind the Audi. 'IF' the newly-created 'contour' is 'streamlined.'
When the flow separates at the original location, it reattaches by the new trailing edge, capturing a 'locked'-vortex' which continually circulates within the confines of each cell, fed by momentum interchange from the local streamline into the turbulent boundary layer. This constitutes a cannibalistic loss.
The outer 'inviscid' flow 'skips' over the vortex as if it were a phantom surface.
Since the new trailing edge is at a smaller cross-section, the inward rushing flow experiences an acceptable level of deceleration as the streamlines diverge, causing the pressure recovery, which is responsible for all meaningful drag reduction.
According to Mair's research, where an actual boat-tail would provide a negative Cd 0.099 drag reduction, a box-cavity of the same 'elongation' will provide a negative Cd 0.053 reduction ( 46.4% less efficient ).
If the box-cavity were to be 'skinned' at a later date, creating an actual 'boat-tail', then the performance would improve by 46.4%.
freebeard (12-08-2022)
