Old 01-13-2023, 09:29 PM   #86 (permalink)
Xist
I sprayed with the carwash, hosed, sprayed degreaser, hosed, scrubbed with detergent, and hosed:
Foot spray--after driving 40 miles:
The transmission is dripping fluid:
There is fluid as high as I can see!
Two guys suggested I just need to replace the internal gaskets and seals.
One guy claimed to be a master mechanic and said to spend 10 minutes cleaning so I can tell where the leak is.
Another 600 seconds?!
One guy suggested the transmission seal at the CV joint is leaking.
This makes the most sense to me, far more than the top of the transmission leaking.
ID:	33190   Click image for larger version
ID:	33191   Click image for larger version
ID:	33192   Click image for larger version
