Old 01-17-2023, 10:57 PM   #8 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
I used butyl tape to seal the holes when I drilled the roof of my Astro Van to add a rack to hold my solar panels.
I drilled the holes, cleaned the area with alcohol, put down the tape, and then bolted down the rack on top. It has been leak free for 6 years now. If you are leaving your factor rack off use a bolt and washer to fill the hole and provide for a solid cover over the tape.
https://www.homedepot.com/p/Dicor-Bu...34-5/310964213
The Following User Says Thank You to JSH For This Useful Post:
ECO-AKJ (01-18-2023)
