01-12-2023, 12:31 PM
Focused on MPG
Roof Leaks Water
I am having trouble with water leaking from my roof where I had bad seals on the roof racks on my 2006 Mariner(Escape), I have removed the roof rails, put gorilla tape over holes, sprayed a rubber coating on both sides, got the passenger side sealed up but the driver's side still leaks like crazy in a rain storm, the headliner will get soaked from the windshield to just past the B-pillar, any help would be appreciated
Thanks
Staying Focus'd on MPG
01-12-2023, 02:15 PM
What's the diameter of the hole? Headliner in the way?
Back in my day there was so much toilet paper and eggs that we would throw them at the houses of our enemies
01-12-2023, 02:59 PM
Focused on MPG
Probably a 1/4in, I have put silicone in all the holes and put gorilla tape over that and it still leaks, I seen some rubber strips about 4-6 inches wide and about an 1/8in thick, I had thought about those but I am undecided.
01-12-2023, 04:09 PM
01-12-2023, 09:49 PM
Quite surprising that silicone didn't work. BTW have you never tried expansion foam?
01-13-2023, 11:22 AM
Believe it or not, car wax is a really effective mold release. My thought is the leak originates from a windshield seal failure or a weld seam in the same area.
01-13-2023, 12:47 PM
Yeah, my only leaks have been from windshield gasket and a folded seam in a firewall that was damaged from a collision.
01-17-2023, 11:57 PM
AKA - Jason
I used butyl tape to seal the holes when I drilled the roof of my Astro Van to add a rack to hold my solar panels.
I drilled the holes, cleaned the area with alcohol, put down the tape, and then bolted down the rack on top. It has been leak free for 6 years now. If you are leaving your factor rack off use a bolt and washer to fill the hole and provide for a solid cover over the tape.
https://www.homedepot.com/p/Dicor-Bu...34-5/310964213
The Following User Says Thank You to JSH For This Useful Post:
01-18-2023, 12:00 AM
#9 (permalink)
AKA - Jason
I have 5 of those in the roof of my ambulance where they removed the light bar. They used silicon and those plugs and 3 out of 5 of them leak. Right now I have duct tape (The aluminum tape actually used for ductwork) over the top as a temporary fix.
The Following 2 Users Say Thank You to JSH For This Useful Post:
01-18-2023, 12:38 AM
#10 (permalink)
Ethyl or isopropyl?
