Originally Posted by Xist
None of that seemed like it would take long, but it rarely does.
It seemed to take hours to find my Hondabond, but I straightened quite a bit of my room.
I need to clear off my bed again.
I made my brother's breakfast, supervised his speech therapy, took him to lunch, Dollar Tree, and Harbor Freight, and made whatever this is:
When do I fix my car?!
I twisted shop towels and pushed them into my spark plug wells, and then twisted in the other end.
The top and bottom quarters of one of the towels was soaked, so I put a clean one in there.
I just want to spray brake cleaner in there and then compressed air.
I don't have misfires.
The PCV hose was difficult, but for some reason it and the other hose have outer hoses, and I need to figure out to work the other outer hose back.
I didn't use the wire brush. That should only take a minute--when I remember.
I called Hatch and just left a voice mail. I sent an e-mail and the guy called back.
He said it will take a day or two for the hose and 1-2 weeks for the cowl gasket.
About eighty dollars for two relatively-small pieces of rubber.
They are open Saturday, so hopefully I have it this week.
I tried using my pink plastic scraper and pink razor, but they just bent, so I used my carbide scraper to clean the mating surfaces, but I went along with the mating surface, so the scratches go the right way.
The beads of seal packing are for where the timing cover attaches.
I don't have clients until 1300 tomorrow, so hopefully I can knock out a bunch more.
