Old 01-21-2023, 12:30 PM   #79 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Originally Posted by hayden55 View Post
landlord special. You just paint over the damage, window frames, plugs, switches etc...
Drives me absolutely insane. I can tell the previous homeowner did a lot of their own painting here with how sloppy it was done. I don't think they even sanded when they painted the cabinets from green to white. Bump them, and the white peels off and reveals a the green coat.
For some reason it really bothers me when people get sloppy near the ceiling, and don't care that they've created green streaks on the white ceiling. Even if they're too lazy to tape it off, latex paint cleans up super easy such that just having a damp rag on you would be sufficient to wipe the big mistakes away.
I'm not looking for perfection, just doing the reasonable things like taping edges and removing outlet covers. At minimum, sanding patches in the drywall so it isn't a lump. I'm going to have to learn how to feather it in and retexture, because if I'm going to spend time on something, I want it done right.
... I've got a couple extra holes I made when installing my theater system. One of them I drilled thinking it led between the floor joists of the ceiling/floor above. I didn't conceptualize the staircase in-between, and was surprised to see light coming from the hole after I drilled it. I'm tempted to use a hole saw and just cut the right size from scrap drywall I've got, but I'm sure the professional repair would be to cut a square around the hole, then fill that.
