Old 01-28-2023, 02:31 AM   #18 (permalink)
Xist
Even if your power steering leak is small, I recommend at least figuring out from where it is leaking and where the fluid is landing.
A power steering leak ruined the rack and pinion and alternator belt in my Prelude, and apparently the alternator died when the belt snapped.
An oil leak in the Accord ruined the distributor, starter, spark plugs, wires, and caused misfires.
An oil leak in this Camry ruined a hose and a seal.
Unless a leak is on the bottom and will only ruin the ground it will probably cause other components to fail.
Ecky (01-28-2023)
