Old 01-28-2023, 02:47 AM   #21 (permalink)
Christian
EcoModding Noob
Christian's Avatar
Mazda 3 - '16 Mazda 3 Hatchback GS
Thanks Xist,
I should have clarified in my post, the leak is coming from the steering rack rubber boot. It appears that nothing should be damaged by the leak, but I appreciate the heads-up. I didn't really consider how much damage the fluid itself could cause.
Even if your power steering leak is small, I recommend at least figuring out from where it is leaking and where the fluid is landing.
A power steering leak ruined the rack and pinion and alternator belt in my Prelude, and apparently the alternator died when the belt snapped.
An oil leak in the Accord ruined the distributor, starter, spark plugs, wires, and caused misfires.
An oil leak in this Camry ruined a hose and a seal.
Unless a leak is on the bottom and will only ruin the ground it will probably cause other components to fail.
