It
is was the part plus supports.
Originally Posted by DDG
https://3dprinterly.com › how-to-3d-print-without-getting-layer-lines
8 Ways How to 3D Print Without Getting Layer Lines
How to 3D Print Without Getting Layer Lines? 1. Reducing the Layer Height 2. Adjust Nozzle Diameter 3. Fix Mechanical Issues 4. Find Your Optimal Printing Temperature 5. Use High Quality Filament 6. Adjust Model Orientation 7. Avoid Temperature Fluctuations 8. Correct Over-Extrusion Other Methods to Remove Layer Lines
