Old 01-28-2023, 12:16 PM   #21 (permalink)
It is was the part plus supports.
Originally Posted by DDG
https://3dprinterly.com › how-to-3d-print-without-getting-layer-lines
8 Ways How to 3D Print Without Getting Layer Lines
How to 3D Print Without Getting Layer Lines? 1. Reducing the Layer Height 2. Adjust Nozzle Diameter 3. Fix Mechanical Issues 4. Find Your Optimal Printing Temperature 5. Use High Quality Filament 6. Adjust Model Orientation 7. Avoid Temperature Fluctuations 8. Correct Over-Extrusion Other Methods to Remove Layer Lines
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
Old 02-01-2023, 01:28 AM   #22 (permalink)
Originally Posted by Vekke View Post
I can also print blocking plates for original mirror place so its easy to swap for inspection the oem mirror.
What would be the issue with the other mirror during an inspection?
Old 02-10-2023, 02:03 PM   #23 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Size is 1/3 of the official size and it does not have eu approval.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
aerodynamics, audi a2 1.4tdi, efficiency, fuel consumption
