Old 01-29-2023, 07:11 PM   #28 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
I would always run ~44-48psi in my winter tires - they seemed to cut through the snow better.
You don't entirely lose power brakes when EOC, there's a check valve going to the brake booster. You typically get 6-8 solid hard stops before the vacuum assist starts to fade, and it's gradual, so you can feel it and bump start the engine.
Christian (01-29-2023)
