Old 02-02-2023, 09:11 PM   #44 (permalink)
Christian
EcoModding Noob
Christian's Avatar
Mazda 3 - '16 Mazda 3 Hatchback GS
Originally Posted by Tmugz88 View Post
I'm new here but wouldn't leaving an opening like you did negate the purpose of the grill block? No disrespect towards you I honestly am asking a question because I truthfully don't understand how this would improve aerodynamics enough to justify the work. Could you do a full block and utilize the pipe insulation as a spacer to allow some air to enter/exit ?
I believe you're right, it definitely seems like it would have a poor effect on aerodynamics. I can't really speak on exactly how much of a negative impact it would make though.
However, my goal for the mod is to increase the warm-up time of the vehicle, not improve aerodynamics. The large majority of my driving is short stop & go city trips. I plan on also building an upper grille block eventually to help increase the temperature of air coming through the intake.
The Following User Says Thank You to Christian For This Useful Post:
EcoCivic (02-02-2023)
