My biggest fear would be cutting a hole in the roof that you cannot plug completely in winter. That and wind noise.
I find that the vents coupled with a window cracked on the passenger side gives lots of ventilation. Light clothing, shorts and a synthetic T shirts helps. I have experimented with a chiller pad, used for recovery from knee surgery, which runs off a small inverter and ice water from the convenience store. I put it on my neck and back and it will really cool you off. You can probably find one lightly used for cheap.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
