Old 02-04-2023, 07:38 PM   #2 (permalink)
Dodge 1996 4x4 Dan
Your 120v circuits are going to be wired to one or the other of the 2 phases of the 240v service entrance voltage.
You will have to take that into consideration and jumper the two 120v together. Not a good thing if you forget to un jumper and go back to grid power.
I think you are going to pop something when trying to hook the inverter and generator power together.
Power line workers have been killed by back fed home generated power that reaches the transformer and then gets 'stepped up' to 12k or so volts on the grid that they know is turned off.
The Following 2 Users Say Thank You to Dodge 1996 4x4 Dan For This Useful Post:
Cd (02-05-2023), redpoint5 (02-04-2023)
