Old 02-06-2023, 05:17 PM   #1033 (permalink)
freebeard
You're good with numbers. What effect from 8,500-15,00 tons per day of Carbon Dioxide (using Sulfur Dioxide as a proxy)?
Kīlauea - Volcano Updates | U.S. Geological Survey
4 days agoVolcanic tremor remains above background levels. A sulfur dioxide (SO 2) emission rate of approximately 3,000 tonnes per day (t/d) was measured on January 20, 2023. Rift Zone Observations: No unusual activity has been noted along the East Rift Zone or Southwest Rift Zone; steady rates of ground deformation and seismicity continue along both.
https://newrepublic.com › article › 148542 › kilaueas-impact-climate
What Is Kilauea's Impact on the Climate? | The New Republic
Though he doesn't have exact measurements, he estimates that Kilauea is emitting around 15,000 metric tons of carbon dioxide per day. (He calculated this based on measurements of sulfur dioxide...
https://agupubs.onlinelibrary.wiley.com › doi › full › 10.1029 › 2001JB000407
Carbon dioxide emission rate of Kīlauea Volcano: Implications for ...
[1] We report a CO 2 emission rate of 8500 metric tons per day (t d −1) for the summit of Kīlauea Volcano, several times larger than previous estimates. It is based on three sets of measurements over 4 years of synchronous SO 2 emission rates and volcanic CO 2 /SO 2 concentration ratios for the summit correlation spectrometer (COSPEC) traverse.
Plus the 3,00 tons per day of Sulfur Dioxide itself?
https://tools.niehs.nih.gov › cchhl › index.cfm?do=main.detail&reference_id=8437
Sulfur dioxide initiates global climate change in four ways
Global climate change, prior to the 20th century, appears to have been initiated primarily by major changes in volcanic activity. Sulfur dioxide (SO2) is the most voluminous chemically active gas emitted by volcanoes and is readily oxidized to sulfuric acid normally within weeks. But trace amounts o SO2 exert significant influence on climate.
The wages of woke is broke[™] -- Harvey Cthulhu
aerohead (02-06-2023)
