Old 02-13-2023, 12:22 PM   #885 (permalink)
aerohead
'Total Solar Irradiance'
Sunspots do not dominate total solar irradiance.
Peak-to-peak, eleven-year Solar-Cycle total illuminosity is related to the statistical quantitative evaluation of all magnetic flux-related, dark sunspots ( which do not block UV radiation ), and bright, interactive regions :
* moats encircling sunspots
* magnetically-induced faculae in the photosphere, brighter than surrounding senescent solar disk
* plage fields which appear co-spatially with faculae, covering an order of magnitude larger area than sunspots ( 10X ) and are longer-lived than sunspots
During solar maximum, each cycle, when there is the highest population of 'dark' sunspots, the Sun is at it's 'brightest.'
Dramatic daily solar ejaculations mean nothing in the aggregate, as solar physicists routinely track 81-day running means, covering three solar rotations each, recording all spectra, at all latitudes, through all angles, for eleven years, since Solar-Cycle-1, June-July, 1754, when official record keeping began.
And one for you climate deniers to chew on:
The 2014 Solar Maximum was among the weakest maximums ever recorded since 1754, Earth set an all-time heat record, while the Moon, nor any of the other planets varied in temperature at all.
