Old 02-13-2023, 03:26 PM   #894 (permalink)
aerohead
circuit flow
Fact if there's a 1 ohm and a 10 ohm path for current to flow. If current follows the path of least resistance than the 10 ohm path would have no current flow. This is wrong and easy to test.
A corrected ohms law would say something to the effect of "current flow is proportional to resistance".
Okay, so let's say it's a DC circuit, and the positive source shares a parallel trace two both resistive loads.
You close a switch, and current flows to both loads, since both see the same potential to ground.
I'm guessing that if you have inline ammeters at each load, that the 1-ohm load will see ten times the amount of amperage flowing to ground, compared to the 10-ohm load?
Is that the gist of where you were going?
