If you pick the method of battery assembly carefully enough, some of these packs disassemble rather easy making cell replacement almost a DIY home process. Prius and chevy come to mind. Power electronics replacement becomes the next issue, but the aftermarket bunch seem to be gaining on that with newer more efficient controllers and chargers. All the other stuff appears to be arriving in the aftermarket. So other than one-off stuff specific to the vehicle like door skins, owning an older common model appears to be typical used car shade tree garage mechanic stuff with a big instant fatality option.
Reason: Asked to by psyborg
