Thread: Rust
Old 03-02-2023, 04:49 PM   #1 (permalink)
oil pan 4
Rust
One sauce to rule them all?
I knew ATF was probably better than wd40 or pb blaster but I had to be able to drip some ATF on the offending parts and let it sit for at least overnight or apply heat with a torch. When torching or inductively heating wd40 and pb blaster burn off almost instantly, ATF hangs around for a bit before burning off.
The advantage of pb blaster or wd40 is it has a red straw sprayer that gets it into places where ATF cant.
For the last decade or so I mostly use wd40 as cleaner and pb blaster for rusty stuff.
I guess cutting atf with solvent makes it work faster?
By the looks of it I should just dump my pb blaster in the nearest Ohio river and get liquid wrench or that other one I never heard of.
Surprisingly this isn't a post trashing Alec Baldwin for shooting that lady who was by total coincidence was filming a documentary on child trafficking. But it can be.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
Ecky (03-22-2023), ME_Andy (03-05-2023)
