Old 03-06-2023, 12:39 PM   #948 (permalink)
aerohead
'Space weather and Earth 'seismicity''
The following may explain the cognitive dissonance surrounding the 'so-called' space weather / Earth earthquake connection.'
1) Seismometers contain ferrous metal components.
2) Ferrous metal components are sensitive to magnetic fields.
3) Electromagnetic shielding of seismometers is very expensive.
4) Near-polar, un-shielded seismometers, as in 'ALL' of the 'Alaskan-193, Transportable Array ( TA ) are susceptible to space-weather-induced Geomagnetically Induced Current ( GIC ) electromagnetic interference, deflecting like compass needles, and introducing 'noise' into the seismographic recordings.
5) The USGS maintains a network of 'All-Sky' cameras, which monitor auroras, and magnetometers used to remove the 'noise; from seismometers.
6) The seismologists get 'clean' earthquake data.
7) And space physicists get 'free' space weather data, by default.
The takeaway is that, space weather doesn't affect seismicity.
Seismometers 'MAY' record 'shaking' where NONE is occurring.
Magnetically-shielded seismometers, right beside their 'cheap' un-shielded neighbors, indicate 'ZERO' shaking, and zero effects from solar storms.
The phenomena has been understood since February 2, 2019, when the Black Forest Observatory, Schiltach, Germany recorded a magnetic storm on their seismometer.
