Old 03-07-2023, 04:06 PM   #12 (permalink)
Phase
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Originally Posted by DieselCruze View Post
Another question came to mind while comparing the available specs on these three tires: The Goodyear states a max psi of 51, while the Michelins and Bridgestones list a max psi of 44. I like to run 40-41 psi in my current Goodyears and I'm wondering if having a lower max psi might make it a bit dodgy to run that high? Is the lower psi limit a negative? Or does it really not make a difference what the limit is, as long as I'm under it. Just wondering if that is something I should factor into my decision.
no idea. could just be stiffer tread and rubber so the psi doesnt need to be as high. i run all my tires at 40 psi, but theyve gone up to 46 psi in warmer weather on the highway and no issues
