03-07-2023, 03:31 PM
#11 (permalink)
Algie - '18 Chevrolet Cruze Diesel 90 day: 57.45 mpg (US)
Another question came to mind while comparing the available specs on these three tires: The Goodyear states a max psi of 51, while the Michelins and Bridgestones list a max psi of 44. I like to run 40-41 psi in my current Goodyears and I'm wondering if having a lower max psi might make it a bit dodgy to run that high? Is the lower psi limit a negative? Or does it really not make a difference what the limit is, as long as I'm under it. Just wondering if that is something I should factor into my decision.
03-07-2023, 04:06 PM
#12 (permalink)
no idea. could just be stiffer tread and rubber so the psi doesnt need to be as high. i run all my tires at 40 psi, but theyve gone up to 46 psi in warmer weather on the highway and no issues
03-07-2023, 04:42 PM
#13 (permalink)
AKA - Jason
I wouldn't worry about the difference between 44 and 51 PSI. Either will do fine at 40 psi. (I run 40 - 45 PSI (cold) in my FWD vehicles with 5 PSI more in the rear)
Originally Posted by Phase
Thank goodness my ecopias were only 350-400 bucks from Costco for a full set. Only bad reviews I’ve seen is the tread wears faster than Michelins
Prices went up a lot last year. For reference I paid $671.80 for the Michelin Pilot Sports with the same $150 discount. (Which is the most I've ever paid for a set of 4 tires)
The Following User Says Thank You to JSH For This Useful Post:
03-07-2023, 05:38 PM
#14 (permalink)
keep in mind my car runs 15 inch tires. so its usually cheaper
03-07-2023, 05:39 PM
#15 (permalink)
The Pilot Sports are pretty nice tires. They're also... well, low rolling resistance for their class.
03-07-2023, 08:02 PM
#16 (permalink)
AKA - Jason
Yes, 15 inch tires are cheaper. The Bolt is rolling on 15 inch snow tires today for that very reason
Yes, they are very nice tires. I wasn't expecting the 20% drop in range though!
03-08-2023, 12:08 AM
#17 (permalink)
im curious to when they will release the super ULTRA lrr tires that are being used on the light year zero and mercedes eqxx
03-08-2023, 12:27 AM
#18 (permalink)
From these cars they'll probably be 20" or larger, with an extremely low profile (30?).
