Old 03-07-2023, 08:07 PM   #31 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Most people don't take even the slightest bit of effort to prepare for weather emergencies. The average TV consumes 150 watts and an inverter sized to run a TV and a fridge is $70 to $200.
I recently picked up an 800 watt Sportsman inverter/generator for $95. Supposedly runs 6 hours on half a gallon of gasoline.
It was somewhat of an impulse buy as my dad has several generators, but they aren't the inverting kind. It's the smallest and lightest genset around, and fairly quiet.
I like the Ecoflow Delta, but way misunderestimated the price. Here is more power for less money.
I've been critical of every powerstation "deal" on Slickdeals recently, because what are the odds that a powerstation has exactly the capacity you need, and exactly the power output capabilities?
Better to have a separate inverter and battery, than an all-in-one unit that will get tossed in the garbage once the batteries wear out. Cheaper, and you can size it to your needs.
Then again, I'm the sort of person that can't stand combo modem/routers. Most people prefer them for the simplicity though.
Originally Posted by Isaac Zachary View Post
Generators can also be deadly. Even making sure it's outside isn't enough. 50% of carbon monoxide deaths from generators were from generators that were outside.
Edit. Of course using a car with an ICE for the same reasons is also dangerous.
This does bring up a question though. What battery would work in a cold climate like mine? Or what can be done to keep one from freezing? We still have several feet of snow and quite a while before it's warm again.
Many (most?) gensets have CO detectors. You can buy a battery operated one for like $5. Generators are the way to power people who live in CO, not batteries... and I just realized Colorado is Carbon Monoxide. That's unfortunate.
