Old 03-23-2023, 12:51 PM   #29 (permalink)
aerohead
'combustion'
Maybe internal combustion is not the problem, but the crank and rod?
www.youtube.com/results?search_query=Omega+1+ice+engine+design
It's the products of combustion.
If a cost-effective means can be effected, which captures and sequesters all methane and carbon dioxide, plus remove all the extant methane and carbon dioxide from the atmosphere, back down to pre-industrial levels; then it would be less of an issue.
The fly in the ointment though, is the superior efficiency of the electric motor, compared to internal combustion.
There is a downward trending curve for any compelling arguments suggesting that in a capitalistic nation, anyone could justify the use of internal combustion for any longer than absolutely necessary, in the transition to electrified transport, or anything else which would benefit from electrification.
Ecky (03-23-2023), freebeard (03-23-2023)
