Old 03-31-2023, 11:11 AM   #15 (permalink)
aerohead
'hot garbage'
No they weren't. If you think going from 55mph to 87mph is only going to cut the range in half your, numbers are hot garbage.
The scientific fact is that:
If a RIVIAN or F-150 LIGHTNING gets 300-miles of range pulling the LightShip at 55-mph, then in order to cut the range down to 150-miles, you'd have to pull the trailer at between the two speeds I posted.
If you want to argue terminal velocities of sky divers in a 'hard-arch' I'll be happy to engage you on that as well.
Physics is physics.
As I've said, Americans do not understand aerodynamics.
Any rebuttal must include mathematics.
