Fuel Efficient Camshafts
Unfortunate circumstances means doing a valve job on my 2001 Toyota Corolla. While I have the head off, I'm wondering if there are any mechanical mods I can do to aid in fuel efficiency. I know there are "performance" camshafts, but not sure what these do for fuel efficiency. Is there anything available out there or do I need to get a grind to get a better profile? Is it even possible to get a more fuel efficient profile from the Toyota factory cams? I have VVT so maybe none of this is possible?
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
